Getting ready for plenum fix and tune up
Old Jun 11, 2010 | 12:25 PM
DukeSupes's Avatar
DukeSupes
Originally Posted by bigtman07
That's about the size of it. Not to terrible looks worse than it actually is. Just be careful of the hose that goes from the water pump to the intake. It likes to break on ya.
Gotcha. Well this aint my first RODEO with a 318 Man I really miss my Charger
Old Jun 12, 2010 | 09:33 PM
DukeSupes's Avatar
DukeSupes
Well here are some pics of the work I got done today. The Hughes plenum fix kit will be here Monday and I wanted to tear it down early to find and replace any casualties and do a lot of clean up before then. As you will see there was a blow out and it left a nice thick build up on the inside. 6 dollars at the power wash, and 2 cans of carb cleaner later, it looked much better. So far I only have 3 casualties. I had 2 intake bolts snap on me. Soaked them in wd40 and used a pair of vice grips to turn the studs out. The third was the oil pressure switch at the back of the block. I hit it pretty good with the vice grips while turning the very far back passenger side intake stud out. Pictures are not in order.
https://dodgeforum.com/forum/members...ms-plenum.html
