A little help for a little leak..
So i replaced the water pump a while back and have a small coolant leak while there is pressure in the system. I'm guessing it's coming from behind the water pump where i did not clean off the old gasket. Does this sound like a common diagnosis of this leak?
Permatex makes a tube of gray RTV specifically for coolant. Comes in a small tube and works great. If you can't get the leak stopped try smearing that on the metal surfaces to fill gaps in the metal and clean all the old gasket off.
a little extra time scraping can save a bunch of time later...
He is not talking about smearing it around the outside.(which will never work anyway) He is talking about doing it correctly when it was/is apart.
Trending Topics
