Dist cap & wires - I messed something up
Old Jun 11, 2010 | 03:52 PM
M Laborde's Avatar
M Laborde
Default Dist cap & wires - I messed something up
I was changing my plugs & wires today & checked the dist cap & rotor. The cap and rotor were corroded so I replaced them also.
I transferred each wire from old cap to new cap in what I thought was the same position but I apparently screwed something up.
The truck won't start.
I have a Haynes manual and see the diagram of the cylinder #s and firing order. If #1 on the cap is supposed to wire to #1 cylinder (and so on) then my wires definitely are wrong. Is that how it's supposed to connect?
Thanks for the help in advance!
Old Jun 11, 2010 | 04:12 PM
Maxx_Magnum's Avatar
Maxx_Magnum
yes that's how they go. #2 on the dist to #2 cylinder and so on. And don't forget about the coil wire
Old Jun 11, 2010 | 04:15 PM
M Laborde's Avatar
M Laborde
Thanks! I'll post later how I have them. Is 1 out of 8 bad? LOL! I have NO IDEA how i screwed this up so badly.
Old Jun 11, 2010 | 04:27 PM
Maxx_Magnum
don't feel bad, once years ago I was changing the wires on an old 4 cylinder beretta, the coil packs were on the backside of the motor so I had to do it by feel, and I had those FOUR messed up just as bad haha
Old Jun 11, 2010 | 04:37 PM
Kaldir's Avatar
Kaldir
Yeah this can happen, no biggie!! Just sucks on where they put the cap. Its a pain in the rear to get to.
Old Jun 11, 2010 | 04:48 PM
dodgeram07's Avatar
dodgeram07
hope this helps.............good luck!!
Old Jun 11, 2010 | 08:50 PM
95RAM360's Avatar
95RAM360
^mine was completly different than that....and i had each one off by one, and mine was still running....but rough....so i dont think routing them wrong will make it not start, id check everyone of them and make sure they are "snapped" down.
Old Jun 11, 2010 | 10:54 PM
M Laborde's Avatar
M Laborde
When you only have 1 in the right place on the cap, it won't run.
I followed the diagram in the Haynes manual, which is the same on that dodgeram07 posted. Runs like a champ.
I felt like such a dumba$$ for about 2 hours this afternoon.
Thanks to everyone for their help... again.
Old Jun 11, 2010 | 11:00 PM
Maxx_Magnum
haha glad ya got er goin bud
Old Jun 13, 2010 | 02:20 PM
03neonSE's Avatar
03neonSE
Just a side note, on the distributor cap. There is a number 1 marked on the cap, then start to work putting the wires on clockwise. I did this and got it right the first time. I'm not braging (sp), just a note.
