got me a package today
Old Jun 11, 2010 | 09:53 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by 95RAM360
not to thread hijack....but is there a way to get a dual intake?l ike have two intake tubes, and two filters going to each side of the truck?
That'd take some custom fab work, and unless your engine is a fire breathing monster it'd be a wasted effort. But if you want to get silly, it's doable.
EDITED TO ADD: And unless you do some air flow measurements, you might end up screwing yourself. I'd guess that the hot ticket if you don't have a flow bench handy would be to get at least a foot of chamber between the junction point of the two tubes and the throttle body so any turbulence has a chance to damp before it reaches your throttle body. Setting up an eddy current, if it lands in the wrong place, can really poo the scrooch.
Way back when TBI was the latest thing we used to replace carbs with aftermarket TBI's on off-road engines that had to continue running (hopefully well) at the extreme angles that would cause carb bowls to overflow. On big block Chevy engines, though, the Edelbrock kit had a funky problem in the throttle body air horn that would set up an eddy current that quite often would park right over a port. That cylinder would run lean as 4377, and the tell-tale symptom was red-hot headers on the affected cylinder, and if you ran the engine long enough (more than about 10-15 minutes) the headers would actually burn through. Edelbrock fixed it by adding an adapter plate to the kit that had a tab hanging out over the throttle body bore to weaken and move the vortex so that the eddy current was then parked out of the most critical path -- it was still in the manifold, but not in the way. The whole even bank would run a tad leaner than the odd, but not enough to cause perceptible problems.
btw...ive been looking into the spectre cai's, since ill probably not have to sell my truck since my family and i are getting back on track ....
SCHWEET! Glad to hear things are looking up for you!
I can't speak about the Spectre, but the K&N I've got works as advertised within the tolerances of my butt dyno's accuracy. I know that a butt dyno is a purely subjective thing, but it's good enough for me.
Old Jun 11, 2010 | 10:30 PM
dodgeman52's Avatar
dodgeman52
u can make a custom one with spectre parts i just don't know about the cost
Old Jun 12, 2010 | 02:13 AM
southern13guy's Avatar
southern13guy
I've seen a dual intake before. Someone did a homemade one a while back; not sure where I saw it. Here's one....http://www.apactonline.com/images/au...s/dualBlue.jpg
