Lift/tires question...
Old Jun 14, 2010 | 10:18 PM
Did your lift also level your truck? If not, you could pick up a leveling kit, and get up to another 2.5 inches that way..... If it did, an add a leaf in the back in combination might help. But, since you are rubbing on steel..... you may need to get different rims.
Old Jun 14, 2010 | 11:17 PM
redheadhunter21's Avatar
redheadhunter21
Do you know the backspacing on the rims you have, and do you have any pictures or can you take a picture of exactly were it is rubbing
It sounds like its more of a rim issue and wheel spacers might help if the bs is too much
Old Jun 15, 2010 | 12:22 AM
Wouldn't spacers just make the problem worse? Sounds like his tires already stick out too far.....
