Timing chain cover bolts
Old Jun 13, 2010 | 06:51 PM
Joey Buentello's Avatar
Joey Buentello
Default Timing chain cover bolts
does anyone have a pic of them?
Old Jun 13, 2010 | 06:59 PM
aje1127's Avatar
aje1127
what do you need to know,just put timing chain gears on my 318 magnum yesterday.
Old Jun 13, 2010 | 07:17 PM
dhvaughan's Avatar
dhvaughan
here's one.
Old Jun 14, 2010 | 08:05 AM
Joey Buentello
I forgot to label my waterpump and timing chain cover bolts when I pulled them out. So when I installed my waterpump I had an extra bolt That didn't look like the others, just wanted to know where it went.
Old Jun 14, 2010 | 07:36 PM
dhvaughan's Avatar
dhvaughan
the odd ball torx? one went in the top center of the water pump. (i think)
Old Jun 14, 2010 | 10:34 PM
Joey Buentello
I had three longer bolts, four shorter ones, and one of the shorter ones didn't have a built in washer like the other seven bolts. It also had threads half way up the bolt.
Old Jun 15, 2010 | 05:37 AM
Joey Buentello
make that 4 longer bolts
Old Jun 15, 2010 | 06:47 AM
dhvaughan's Avatar
dhvaughan
the 4 long ones go through the timing cover water channels and into the block. they are out at the ends at 9'o'clock and 3 o'clock.
the 1 funky one goes at 12 o'clock (i think). i studied that one for a long time trying to figure out why it looked different - w/o success. its still a mystery to me.
Old Jun 15, 2010 | 07:31 AM
Joey Buentello
I just installed it in the timing chain cover, looked like it went there. Do you know how difficult it is to find a stock timing chain cover for a magnum 318>?
Old Jun 15, 2010 | 07:42 AM
dhvaughan's Avatar
dhvaughan
no, i don't. is yours broken ?
try local junk yards, repair shops for ram, ram van, durango, dakota. your cheapest option might be to find someone with a blown up motor that would pretty much give it away.
you could put a parts wanted ad here, and link to it in the sub-forums (ram, dak, etc)
