Does your Ram shake at idle?
Old Jun 15, 2010 | 01:14 AM
hometheaterman's Avatar
hometheaterman
If I do a compression test on this thing which fuse do I pull for the fuel? Will this tell me if I have a cracked head? Also do I take all 8 plugs out? Or do I just take the 4 out on each side at a time?
Also is there a diy on cleaning the iac?
Old Jun 15, 2010 | 01:18 AM
dakotas ram's Avatar
dakotas ram
iac- just remove it and use carb cleaner and lightly clean off the carbon
last spring i had my heads magna fluxed, and a valve job done......its had a "miss" ever since i had it that i can remember
Old Jun 15, 2010 | 02:45 AM
mrfarrell's Avatar
mrfarrell
you need to pull all 8 plugs and there is a diy on the iac cleaning in the diy section i believe its done on a van same thing thou
Old Jun 15, 2010 | 03:04 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Mine dose but I can see the gauge move. But its not all the time.
Might want to look at a new timing change 136k there is a fair amount of slack on that thing, and get a new water pump while you are at it. YOu have to take the water pump off to get to the chain.
Old Jun 15, 2010 | 06:33 AM
DODGEPWR's Avatar
DODGEPWR
Mine runs smooth as butter at op temp at idle. Might wanna replace that CPS..Just a thought. I replaced mine and it ran alot smoother. And what about your FPR(It doubles as a fuel filter) That might be causing it. Just thought id run that by ya.
Old Jun 15, 2010 | 10:12 AM
hometheaterman
So did that reveal a crack or was it fine? What did all that cost? Did your miss go away?
Old Jun 15, 2010 | 10:17 AM
95RAM360's Avatar
95RAM360
I just noticed that you used Platinum plugs....ive heard alot of people say the platinums would make them run rough....but with our trucks its a hit and miss on the plugs....are the plugs gapped correctly?
Old Jun 15, 2010 | 10:24 AM
aim4squirrels's Avatar
aim4squirrels
Pull the ignition system relay, My factory timing chain was shot at 60,000 miles. put a new chain in and it runs smooth as silk.
At idle and low revs, a loose chain will jerk the timing around a bit.
Old Jun 15, 2010 | 10:43 AM
hometheaterman
I have run the oem plugs too with no difference. My truck has done this for as long as I can remember. I also tried auto lites and they were worse. Is there a way to check the timing chain before I replace it?
Old Jun 15, 2010 | 12:27 PM
dodgeram07's Avatar
dodgeram07
+1 did mine at 68,000 my truck runs great at idle
