Going to take motor out ASAP Anything You would do while its out?
Subscribe
Jun 15, 2010 | 07:54 PM
So i have been away for awhile for work out of town and a bunch of side work for extra money. Anyways my truck has been sitting for way to long at this point(since december) and i need to begin work on it again.
I took and put oil in and coolant then jump started it to get it running, As it sits either the head gasket or the head is blown on the driver side. So i started removing stuff so i can get the motor out.
Im going to buy a entire new gasket set with everything needed.
Going to paint it for fun.
Going to put the body lift thats been in my room for over a year in while the motor is unhooked
New rear main seals
Going to have new distributor and wires(just replaced plugs)
Anything else you would aboslutly replace while its out. that is hard to reach while its in
Reply 0
Jun 15, 2010 | 08:01 PM
Rings, rod and main bearings. Oil pump. valve job. Heads checked, (or, just better heads) timing chain and gears. Water Pump. All hoses/belts. Thermostat.
Reply 0
Jun 15, 2010 | 08:06 PM
freeze plugs.
Reply 0
Jun 15, 2010 | 08:25 PM
have you done the plenum? gotta do more than just the gasket, order the plate.
Reply 0
Jun 15, 2010 | 08:28 PM
do you have the plenum fixed?...wow got ninja'd by bigred... i'd look into an airgap if you have the $$$
Reply 0
Jun 15, 2010 | 08:40 PM
might want to flush the raditor out to
Reply 0
Jun 16, 2010 | 10:17 AM
Air gap and roller rockers.
Reply 0
Jun 17, 2010 | 07:20 PM
sorry should have went into detail.
Has 1.7s RRs, Hughes FI Airgap, K&N system, Fastmans TB
but almost all is new(put on Airgap, 1.7s and Fastmans at the same time then i blew a radiator hose about three blocks from my house and over heated it instantly so i havent got to test any parts at all.
How much would you pay for new heads im stuck on this issue. Have a some extra money saved up for new truck parts but im not wanting to go to crazy on new heads since its not a daily driver and its mostly a toy.
Reply 0
Jun 17, 2010 | 09:14 PM
See what Hughes is selling them for.
I saw a top end kit that comes with aluminum heads, airgap, new cam, roller rockers, all necessary gaskets and something else for 3000$, so the heads alone shouldn't be a bank breaker.
Reply 0
Jun 17, 2010 | 09:17 PM
A better design (than stock) head is also available on ebay, for 270 a side, fully assembled.
What kind of budget are you looking at?
Reply 0
