I'm sick and tired of my truck
Old Jun 18, 2010 | 04:32 AM
dakotas ram's Avatar
dakotas ram
its your rearend...... its going bad and is slipping, power is being shifted from one rear tire to the other, making it seem that its the front end but its not
Old Jun 18, 2010 | 04:33 AM
dakotas ram
^ not really
Old Jun 18, 2010 | 06:58 AM
rollingradios's Avatar
rollingradios
I've replaced the track bar 3 times, that always made minor difference.
I ordered the energy suspension complete bushing kit which will go on next month BUT remember I've had this situation get better and worse over time without ever messing with bushings.
Old Jun 18, 2010 | 02:56 PM
dakotas ram
what about your wheel bearings as mentioned before?
Old Jun 18, 2010 | 03:18 PM
dodgeman52's Avatar
dodgeman52
i would grab your steering column as soon as it comes out the cab and check the shaft for any movement because if there is the lower bushing is shot
http://www.*********.com/forums/showthread.php?t=106366
Old Jun 18, 2010 | 04:10 PM
03neonSE's Avatar
03neonSE
Did you replace the steering stabilizer shock? I have yet someone to see someone mention this and I had the exact problem. I replaced mine and I don't have an issue with the truck wondering all over the road......
Old Jun 18, 2010 | 08:03 PM
rollingradios
I've replace the steering shaft and steering box. I've replaced the stabilizer and then even tried removing it.
Old Jun 18, 2010 | 09:16 PM
When was the last time you had it aligned, and what were the specs? And no, just the tech saying "within spec" seems to be inadequate.... need to know the exact numbers.
Old Jun 19, 2010 | 04:48 AM
rollingradios
Had it aligned about 2000 mis ago. I've had this truck to the best alignment shops around. The last guy got it the best by not adjusting to oem spec. I can't recall what it was he did or exact numbers.
I hope someone realizes and notes my first post. I had a 96 ram just like this one that never had this problem
Old Jun 19, 2010 | 09:11 AM
03neonSE's Avatar
03neonSE
I bet you have a loose bolt somewhere along the line, I would re-torque everything and while your there, check you bushings.
