Your A/C best guess....
Old Jun 18, 2010 | 08:12 PM
Jackstand123's Avatar
Jackstand123
Default Your A/C best guess....
Ok I live in Fl and need my beloved ac. Mine usually works great all the time except for a hiccup today. was ready to leave noticed the clutch on the ac was not kicking on so...so I called a Buddie of mine he told me to jump the 2 wires going to what I think is the dryer but is also the home to what I think is called the( low pressure switch) I'm trying to find the name of this part. when i jumped the wire going to it the clutches started working fine and when I plugged back in the wire it stayed working . i just don't want this to go out when i'm away from a auto part store . i stopped at auto zone, the guys there didn't know what i was talking about and I didn't have the patience to deal with them today . any help .Thanks Ron 97 5.9 4x4
Old Jun 18, 2010 | 08:37 PM
1997DodgeRam's Avatar
1997DodgeRam
Best of luck, I chased around an AC clutch issue for 2 years in Bama, and then Florida finally pushed me over the edge to just replace the compressor, ahh sweet cold air.
Mine would work fine until the compressor got hot, so it would blow cold for a few minutes until everything got hot, if you then shot it with something to cool it down it would kick back on. More info on what conditions yours works under will help. I tried jumping the switches, but eventually it was the temp thing that rang true as the indicator the clutch was just failing. Is this an original compressor?
Old Jun 18, 2010 | 08:48 PM
Jackstand123
This is the 2nd compressor 2 maybe 3 yrs old first one was leaking like crazy .and 1st time this has ever happen . Worked great coming home from work . sat 2 hrs and then went to go out for dinner and the no air problem .
Old Jun 18, 2010 | 08:52 PM
ghost4321's Avatar
ghost4321
Sounds like the charge is getting low.
Old Jun 18, 2010 | 08:54 PM
1997DodgeRam
I was assuming you started with this before you even got to jumping the low sensor right?
Old Jun 18, 2010 | 09:01 PM
Jackstand123
Ya, charge is fine no leaks . was in the green on my generic tester . worked fine after jump . plugged wire back in and continued to work . just don't know the name of that part to buy it . If it is not outrageous I want to replace it before it goes out totally.
Old Jun 18, 2010 | 09:11 PM
It is indeed the low pressure switch. If it is TOO low, the switch opens, and the A/C doesn't work.
Old Jun 18, 2010 | 09:16 PM
dlwhitco's Avatar
dlwhitco
The part is called a A/C Clutch Cycling Switch
Old Jun 18, 2010 | 09:21 PM
Jackstand123
Thanks DLWHITCO !!
Old Jun 18, 2010 | 10:47 PM
davidkit's Avatar
davidkit
i have a 97 dodge ram and when i have the temperature turned as far cold as can be it will blow cold for about 20 min. and then would quit but a buddy of mine has a dodge with the same problem and told me to leave 1 to 2 clicks from coldest setting and it would quit thats been what i have been doing and it has worked fine for now.
