a/c coming out of dash vents- worse after tps replacement
Old Jun 23, 2010 | 02:20 PM
  #31
matty675's Avatar
matty675
If there is a junkyard near you, go scouting for a vacuum reservoir. All it is, is a plastic ball, or, some other shape.... with a hose nipple on it. Grab one, install it on your truck, and plumb it in between the check valve, and the a/c controls. Will either significantly reduce, or even eliminate the problem.
ok thanks ill give it a try
Old Jun 23, 2010 | 02:47 PM
  #32
tuski's Avatar
tuski
I'm having the same problem as Matty, although mine is with any air coming through the vents. Ac or not.. Ac doesn't even work.. but any time its on vent and I accelerate it reroutes to the dash, like where the defrost would be, then makes a popping sound and comes back to venting straight again. I'm going to check the check valve you guys mentioned, and as far as I know I do not have a blown plenum.
Also I took the truck in to get that fixed a while ago, like 3 years ago, and they did nothing and charged me like 300$ and said they fixed it.
