a/c coming out of dash vents- worse after tps replacement
Old Jun 23, 2010 | 12:04 AM
  #21
matty675's Avatar
matty675
Well, that isn't very nice.......
My plenum is blown (big time) and my vents actually work pretty good. I am going to take a shot in the dark here, and predict a downstream (other side of the check valve) vacuum leak.
where do u say the leak is again?
Old Jun 23, 2010 | 12:06 AM
  #22
matty675's Avatar
matty675
i have 17 in of vac at idle.. haynes says 17-20in. all of the vac tests that the haynes manual has in it, i performed and found nothing abnormal or wrong. according to the manual i have a healthy engine, not so becuz it burns the hell outta some oil
Old Jun 23, 2010 | 12:08 AM
  #23
The new one should have an arrow for flow direction. or some such. And consider, it has been in there a LONG time, in a HOT environment. The vacuum lines tend to glue themselves to plastic pieces over time..... Careful with it, it also tends to make plastic brittle.... try and twist it back and forth to get it to break loose, then pull it out.
Old Jun 23, 2010 | 12:12 AM
  #24
matty675's Avatar
matty675
if it has an arrow, the arrow wuld point towards the intake right?
Old Jun 23, 2010 | 09:36 AM
  #25
matty675's Avatar
matty675
just noticed that the a/c vac line goin into the cab is cracked, how do i replace it?
Old Jun 23, 2010 | 10:01 AM
  #26
aim4squirrels's Avatar
aim4squirrels
You can cut the plastic line and patch it with vac hose from the parts store. The hose should slide onto the outside of the plastic line. Be sure to go to the parts store before you cut and verify they have the correct size vac tube.
Old Jun 23, 2010 | 01:35 PM
  #27
matty675's Avatar
matty675
ive repaired the hole, now its back to where it only goes to the dash if i give it heavy gas in o/d
Old Jun 23, 2010 | 01:39 PM
  #28
If there is a junkyard near you, go scouting for a vacuum reservoir. All it is, is a plastic ball, or, some other shape.... with a hose nipple on it. Grab one, install it on your truck, and plumb it in between the check valve, and the a/c controls. Will either significantly reduce, or even eliminate the problem.
Old Jun 23, 2010 | 01:47 PM
  #29
Maxx_Magnum's Avatar
Maxx_Magnum
matty did you replace that checkvalve?
Old Jun 23, 2010 | 02:12 PM
  #30
matty675's Avatar
matty675
yes, didnt seem to make a difference
