oil filter question
Old Jun 25, 2010 | 02:25 AM
charlie1935's Avatar
charlie1935
I've been using the bigger filter on my 87 since it was new and the 96 for the seven years that I've owned it.
Old Jun 25, 2010 | 03:58 AM
2001Ram's Avatar
2001Ram
I belive they went to the smaller one to save money! Makes you wonder what else they skimped out on...
Old Jun 25, 2010 | 04:58 PM
plott hound's Avatar
plott hound
the fram ph 8a works fine on my '96 ramm.so does the napa 1515.
Old Jun 25, 2010 | 09:44 PM
Casting intake manifolds? Plenum gaskets? Torque converters?
Old Jun 25, 2010 | 10:05 PM
charlie1935
I had cold start lifter noise when using fram filters, went to NAPA gold and very seldom have it any more.
Old Jun 26, 2010 | 05:08 PM
army_greywolf's Avatar
army_greywolf
suppose it would be bad to tell you fram makes MOST of the various other brands of filters out there excluding wix and a couple others I can't remember, it's been a decade since I worked there.
By far, wix is the best filter you can get for the money.
@charlie1935, due to the orientation of your filter on a dodge ram the actual make of the filter has no bearing whatsoever on startup performance, if your having startup clatter you have an oil pump problem or a severely worn top end.
Old Jun 26, 2010 | 06:26 PM
charlie1935
It has been like that since 1987. Getting away from fram fixed it. Some times it sets for a week or longer.
Old Jun 26, 2010 | 06:32 PM
charlie1935
Fram is part of the Honeywell group and has been for several years.
Champion labs is the largest producer of automotive filters in the U. S. A.
Old Jun 26, 2010 | 09:35 PM
dhvaughan's Avatar
dhvaughan
you need to get out more often
