Thermostat inactive
Old Jun 23, 2010 | 07:31 PM
Gnarkill666's Avatar
Gnarkill666
Default Thermostat inactive
I did the plenum fix about 3 weeks ago, replace'd everything and put in a 180 degree thermostat etc. its running great towed my trailer to the beach over 100 mi each way with no problems. came home from work today and the check engine light came on ran the sct and said the thermostat is inactive. anyone knwo why??
Old Jun 23, 2010 | 07:52 PM
where does your temp gauge hang out at? It is possible that the PCM is seeing the low temp, and never getting up to the 195-200 degrees it expects..... so, it interprets that as a failed thermostat.
Old Jun 23, 2010 | 08:11 PM
nopower318's Avatar
nopower318
+1 The newer trucks will do that.
Old Jun 23, 2010 | 09:18 PM
Gnarkill666
yeah it is running a lot colder then normal, it used to run around 180-190 ish a little below the 210 line now it runs halfway between 130 and the 210 line or lower.
Old Jun 23, 2010 | 09:24 PM
Need to reflash the PCM, so it knows about the lower temp thermostat would be my guess.
Old Jun 23, 2010 | 09:42 PM
dodgeman52's Avatar
dodgeman52
or the temp sending unit going bad
