TB Port-out
Old Jun 24, 2010 | 10:50 AM
a-master's Avatar
a-master
Default TB Port-out
My neighbor is a machinist by trade and I was considering having him grind the horns off the TB and bore it out to 52mm. I trust that he won't mess it up, but what i'm asking is if I have to buy any new parts for the TB before/after it is bore'd out? And is there anything I should keep in mind for this job?
Old Jun 24, 2010 | 11:22 AM
lord0fsal3m's Avatar
lord0fsal3m
you would just need to make an s-bolt to attach your air hat. very easy to do with some 1/4-20 threaded rod. the plans are on www.rm-indy.com/
Old Jun 24, 2010 | 11:23 AM
Depends on how much, and how far down he bores it. Might need to replace throttle blades, if he doesn't go that deep, and you use the stock air inlet, no other parts required. The S bolt mentioned above would be if you went with a round air cleaner on top of the throttle body, replacing the stock setup.
Old Jun 24, 2010 | 02:10 PM
lastrights's Avatar
lastrights
al least flatten the throttle body walls
Old Jun 24, 2010 | 02:28 PM
dodgeram07's Avatar
dodgeram07
any thing bigger than 50mm you will need new throllte plates
Old Jun 24, 2010 | 04:05 PM
aim4squirrels's Avatar
aim4squirrels
and maybe new throttle plates as well...
Old Jun 24, 2010 | 04:24 PM
1998machz's Avatar
1998machz
I just recieved my new plates today.There is a guy on dodge talk that will cut you whatever size you need. He charges $15 for 6 blades ( 2 ea of 3 diff sizes) His Nick is Jbt. He was very good to deal with.
Old Jun 24, 2010 | 04:53 PM
a-master's Avatar
a-master
thanks guys, much appreciated
