Wont Start
Old Jun 24, 2010 | 03:43 PM
edlucky1's Avatar
edlucky1
Default Wont Start
Just took off the intake for the second time now. Rear main seal was leaking so I replaced it and all the other ones just to be safe. Got everything put back together and now she wont start. It turns over but never fires. What do I need to check? I already looked at all the wiring to make sure that it was all connected properly. I did exactly what I did last time I took it apart. Everything was running great then. Any suggestions?
Old Jun 24, 2010 | 03:52 PM
ryan0714's Avatar
ryan0714
fuel rail hooked up? :P
Old Jun 24, 2010 | 04:03 PM
edlucky1's Avatar
edlucky1
Yeah fuel rail is all good.
Old Jun 24, 2010 | 04:27 PM
UnregisteredUser's Avatar
UnregisteredUser
I'd first try to determine which subsystem is failing by testing for spark and fuel delivery.
Old Jun 24, 2010 | 04:44 PM
dodgeboy1979's Avatar
dodgeboy1979
check your battery voltage, if it's too low it may not fire
Old Jun 24, 2010 | 05:18 PM
Sport1500's Avatar
Sport1500
Did you have your battery unhooked for a while?
https://dodgeforum.com/forum/2nd-gen...ont-start.html
Rob
Old Jun 25, 2010 | 02:05 PM
edlucky1's Avatar
edlucky1
Checked for spark last night, Im assuming that you should easily see a spark, so I am not getting any spark at all. I read that I should check my coil for spark. Haven't checked my fuel pressure yet. I am still really confused because everything was working great and now nothing. Its amazing how easily stuff gets messed up.
Old Jul 2, 2010 | 11:41 PM
edlucky1's Avatar
edlucky1
OK no spark from the coil. Did some reading, I believe that my crankshaft position sensor is having a problem. Is their anyway to test this sensor without a scanner?
Old Jul 3, 2010 | 08:49 AM
Not that I am aware of. It is a signal generator, so, an Oscilloscope would work too.... everyone has one of those, right?
Old Jul 3, 2010 | 11:28 PM
edlucky1's Avatar
edlucky1
Replaced the crankshaft position sensor, power coil, still no spark. All I have electric wise to test with is a 12v light and a multimeter. What voltages do I need to check for and what not. I have read the service manual and its not very specific.
The green wire to the coil has continuity, the black one does not. The only voltage reading I can get is while someone starts the truck I get 6v from the green wire to the black one.
Any ideas?
