Wheel question
Old 06-26-2010, 12:43 AM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
2wd most likely not, 4wd you could probrably get away with it
Old 06-26-2010, 12:46 AM
Bubba39047's Avatar
Bubba39047
Bubba39047 is offline
guess only thing to do is put em on and see if would work
Old 06-26-2010, 12:49 AM
Mowhawk's Avatar
Mowhawk
Mowhawk is offline
If your going with a 12.5 width tire, the rims cannot be lower than a 8 width rim. Would be better with an 8.5 or 9.
Old 06-26-2010, 12:51 AM
Mowhawk's Avatar
Mowhawk
Mowhawk is offline
Originally Posted by Bubba39047
on the wheel subject. i got a question about upgrading rims. would the rims off a 2010 ram fit on our trucks without mods? the 17s. here is a picture
Need to check the offset on the 2010 rims, compare it to your current rims. If the offset is low you should be fine.
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Ideally you want the wheel to be 3-4" less than the width of the tire... Most popular size wheel for a 12.5" wide tire is a 9"...
Old 06-26-2010, 01:02 AM
redheadhunter21
Bubba you 2wd or 4x4
Old 06-26-2010, 01:09 AM
Bubba39047's Avatar
Bubba39047
v6. so 2wd. although i treat it like a 4wd
Old 06-26-2010, 04:34 PM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
Originally Posted by Pronk
No the wheels are aftermarket from the last owner,
But i figured a 12.5 inch wide tire will need a wide wheel
for 12.5 they recommend 9" wide minimum and 10" will look the biggest. You can get away with an 8" rim but its not ideal especially when you go with a larger than 15" diameter rim..
Quick Reply: Wheel question
