i neeed help
Old Jun 27, 2010 | 03:12 PM
  #21
ryan0714's Avatar
ryan0714
i hope its a hot girl in a bikini! oh wait.. i have a gf...DAMN!
Old Jun 27, 2010 | 03:19 PM
  #22
94excoupe's Avatar
94excoupe
how bout just a pic of a hot girl in a bikini. that wouldnt be cheating lol. but seriously thanks for the help and ill let yall know if that fixes it
Old Jun 27, 2010 | 03:39 PM
  #23
94excoupe's Avatar
94excoupe
this is what i got when i looked the codes up
po320-ign/dist engine speed input circuit malfunction
p1391- intermediate loss of ckp or cmp
Old Jun 27, 2010 | 03:43 PM
  #24
I got the descriptions off of the FAQ section here.... I don't know how much/if at all things changed over the years. Either way, the codes are pointing to a loss of either crank sensor, or cam sensor..... (cam sensor is in the distributor, correct?) If you have already replaced the cam sensor, and are still getting the same codes..... Try the other one?
Old Jun 27, 2010 | 03:45 PM
  #25
94excoupe's Avatar
94excoupe
ok i just pulled it off a random website. just curious. again thanks for the help
Old Jun 27, 2010 | 03:53 PM
  #26
ryan0714's Avatar
ryan0714
both are like 50 bucks? so i mean just readi what the codes are id lean more for the crank sensor first just cuz the engine speed is from what? how fast the crank spins? just my 2 cents, its gotta be one or the other, but i think the crank sensor would go out first, being in the position that it is in.
Old Jun 27, 2010 | 04:31 PM
  #27
UnregisteredUser's Avatar
UnregisteredUser
P0320: "Ignition/Distributor Engine Speed Input Circuit Malfunction".
P1391: "Intermittent Loss of CMP or CKP".
Me: Puzzled.
With those two codes together it seems like a no-brainer. But it doesn't seem to make sense for your symptom. I'd expect that if either the cam or crank signal is falling out enough to kill the engine at low RPM, it should also present symptoms at higher RPM -- which is why I ruled it out in my thinking last night. Very strange.
I dunno. Crank position sensor, maybe. It seems to be getting the votes anyway in the time since I started writing this, during which I've been thinking, drinking coffee, and scratching my head. If the crank sensor fixes it I'll be filing this one away as something that doesn't entirely make sense to me that should be kept in mind for later.
Old Jun 27, 2010 | 04:35 PM
  #28
I could see how the cam sensor would be the more important of the two, as the cam sensor is the one that is going to determine which injector gets fired, etc. An intermittent signal from the crank sensor, or, no signal at all...... the engine could conceivably just use cam sensor data to keep the engine going..... I have no clue if it actually works that way or not. Haven't delved that deep into it. Yet.
Old Jun 27, 2010 | 04:57 PM
  #29
ryan0714's Avatar
ryan0714
so conclusion= try the 2 sensors. u might just use a meter on the first before buyin anything.
Old Jun 27, 2010 | 05:45 PM
  #30
94excoupe's Avatar
94excoupe
nothing on this truck makes sense. sometimes it acts right and some times it stalls at every stop. maybe its a shorted wire on one of the sensors. ill check it out sometime this week and see what i come up with
