Brake Trouble
Old Jun 27, 2010 | 03:26 AM
pei09's Avatar
pei09
Default Brake Trouble
I have a 2001 dodge ram 1500 4x4. I noticed earlier today that my brakes were somewhat soggy when pressed on. I then notice that the brakes were almost completely non-responsive at anything less then 1000 rpm. So at low rpm I had no brakes and would coast to an eventual stop. Any suggestions? I do not think that it is the vacuum line to the power booster.
Thanks
David
Old Jun 27, 2010 | 04:11 AM
2k10HemiRam's Avatar
2k10HemiRam
Any leaks? I'd start by checking fluid level and doing a good brake bleed. If the bleed doesn't change anything for the better then it could be a part. I'm not a brake guru so I'm just throwing out an idea but it's a good place to start I'd imagine.
Old Jun 27, 2010 | 10:08 AM
Is you pedal soft when you step on it? Excessive pedal travel before getting any stopping action??
+1 on checking fluid level.
Old Jun 27, 2010 | 10:18 AM
ghost4321's Avatar
ghost4321
Check the rubber lines for swelling or blistering.
Old Jun 28, 2010 | 02:15 AM
pei09's Avatar
pei09
Thanks for the help guys. I believe it is my master cylinder...
Old Jun 28, 2010 | 07:40 AM
Bubba39047's Avatar
Bubba39047
mine had to be replaced at about 50k according to the previous (first) owner
Old Jun 28, 2010 | 12:08 PM
1998ram5.9's Avatar
1998ram5.9
try the check valve the connects the line to the booster
