oil pressure help
ok so im new to the dodge gas truck world. ive had a cummins for years but finally found a 4x4 play truck that im going to get today. i was test driving it yesterday and the oil pressure gauge went straight to zero i immediatly stopped and turned it off then restarted it and the oil pressure was normal again. there was no delay like it was a pressure drop it just went all the way down. any ideas what it could be? please help
Welcome to DF. ![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Did the engine start making rude noises when the pressure dropped off?
Check the oil level. If it is low, stepping on the gas will deplete the supply in the pan, and, instantly zero pressure.
Also could be just a bad sending unit. If you have a mechanical gauge you can screw in there, you can verify what the pressure is really doing.
Oil coming up the dipstick???? It isn't OVER full is it??
The OP gauges on these trucks have an electrical sending unit. They are somewhat prone to failure....... The BEST way to know FOR SURE though, is screw in the mechanical gauge (even if it is just a test gauge,) and take the truck for a drive.
Oil coming up the dipstick is an entirely separate issue. How many miles on the truck?
Trending Topics
If there was a LIGHT vacuum at the oil cap, PCV is working as it should be. If it tried to suck you in, then there is another problem. (possibly blown plenum gasket, or, stuck open PCV valve.)
Pull the PCV valve, and give it a shake, should rattle a bit. While it is out, (engine running, oil cap back on) there should be a bit of a breeze coming out. But, not much of one......
The oil climbing the dipstick really makes me nervous though. If you pull the dipstick while the engine is running, and everything else hooked up, do you get oil out of it??
That's just odd...... ![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
Check pressure with a mechanical gauge, and see what it says. Take it from there. If you have to have your dad's approval for the purchase though...... might have a bit of a hard time getting the climbing oil thing past him.....
Of course, I would expect the oil to be further up the stick if you pull it with the engine running......
