update on reman 5.9 mag on ebay
Old 06-28-2010, 10:27 PM
matty675's Avatar
matty675
matty675 is offline
Default update on reman 5.9 mag on ebay
so the guy said that i do indeed have a roller engine, but it is only $100 extra for a roller engine. i asked him if i culd use a non roller and he chuckled saying- i wuldnt. anyhow he said the warranty is all inclusive and theres no fine print... it throws a rod threw the block in 1 wk or 4yrs hell replace it for free. i can install the engine and mod it and that WONT void the warranty, however any new parts that i install are ofcourse not covered by his warranty. he also said he culd do upgraded heads for 700 wich i dont think ill get into. but he said he culd do a more aggresive cam for 100, WHICH im definetly gonna do! all engines are made to order. any other mods i shuld ask him about, like how much he wuld charge to do such and such...reasonably cheap?? he also said to send it back if it doesnt run as good or better than a 5.9 from the chrysler plant. link below
http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
Old 06-28-2010, 10:29 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
good deal IMO. do it.
Old 06-28-2010, 10:32 PM
matty675's Avatar
matty675
matty675 is offline
o yea man just need a little more cash to sink into. just wondern if u guys had any input onit
Old 06-28-2010, 10:36 PM
matty675's Avatar
matty675
matty675 is offline
also what do u guys think a cam will do for it?
Old 06-28-2010, 10:38 PM
aim4squirrels
With a 4x4, make sure the cam is modest and keeps your powerband low with good torque numbers at low RPMs.
No sense making 500hp at 6000rpms if you're crawling in 4LO for 5 hours a day.
You are replacing an old 360, correct? not swapping a 318 to a 360, right?
I'd ask him for brass core (freeze) plugs, and a timing chain tensioner to be installed.
Old 06-28-2010, 11:00 PM
matty675's Avatar
matty675
matty675 is offline
it is 4x4 but i only use it on rare ocassions. what are the benefits of the upgrades u listed?
Old 06-28-2010, 11:01 PM
matty675's Avatar
matty675
matty675 is offline
and yes i currently have a 360
Old 06-28-2010, 11:42 PM
EndIsNear's Avatar
EndIsNear
EndIsNear is offline
Timing chain tensioner will take up the slack in the chain that develops over time due to our blocks wide gap between the camshaft and crankshaft. The gap makes stroking our engines easier, but causes the excess slack in the timing chain.
Old 06-28-2010, 11:45 PM
EndIsNear's Avatar
EndIsNear
And the brass core freeze plugs seal easier and don't corrode. Definantly a plus if you get the block.
Old 06-29-2010, 01:27 AM
J415's Avatar
J415
J415 is offline
I'm always the skeptic. How long has this guy been around with his shop and how much experience does he have? That sounds pretty good, thats what scares me.
Quick Reply: update on reman 5.9 mag on ebay
