Motor SWAP "i NEED HELP" ram to durango
Old Jul 2, 2010 | 10:09 PM
Yep, PM HemiFever on this forum, he should be able to help ya out.
Old Jul 3, 2010 | 01:57 AM
Bubba39047's Avatar
Bubba39047
i have questions on your swap. what all did you have to swap? i know the wiring junk is posing a problem but like motor mounts n stuff, air cleaner etc.
Old Jul 3, 2010 | 12:16 PM
socal101703's Avatar
socal101703
Everything bolted right in air cleaner motor mounts its a pretty basic swap besides i am not an electrician so the wiring kills me.
Old Jul 4, 2010 | 02:34 AM
Bubba39047's Avatar
Bubba39047
cause im wantin to do the same thing. probably not FROM a durango but another ram. i got that crappy v6
Old Jul 4, 2010 | 11:20 AM
socal101703
Yea i hated my v6 i was losing oil pressure not sure where cause i replaced oil pump, sensor, i even tried putting lucas oil in it! the truck never knocked or anything,. so i got a good deal on a v8 so i took it. But switch the v8 out of a ram to your ram would be really easy!
Old Jul 5, 2010 | 08:39 PM
socal101703
Default In need of help! =( Electrician/ pcm master
Well basically im getting the run around here cause you guys are saying to buy a harness out of a ram plug it into the durangos pcm! well when i was going to buy one today the ppl where saying that its not going to work because of the pin outs! They where saying it will plug in but pin outs are diff cause its a diff truck! not sure if i should spend 200 $ on a harness if its not going to work! they where saying i have to get the same exact wiring harness as the numbers on the harness!
Old Jul 18, 2010 | 08:11 PM
socal101703
Well i did what you told me i went and got a wire harness out of a dodge ram 360 and for some reason i am not getting spark! I am very confused and need help from a dodge guru!
Kyle,
Old Jul 19, 2010 | 02:50 AM
mrfarrell's Avatar
mrfarrell
what pcm did you use?are there any codes?
Old Jul 19, 2010 | 10:16 AM
socal101703
well it was the distributor! but i used my v6 pcm and the durango pcm and it would start with both butim also using the v6 harness so its running like **** cause 2 injecters are not plugged in,. and it kinda feels like its not getting enough fuel.
Old Jul 19, 2010 | 08:24 PM
mrfarrell's Avatar
mrfarrell
...this is beyond me...anyone else?
