hard to steer when slowing down or in parked
Old Jun 30, 2010 | 03:29 PM
deathwatch789's Avatar
deathwatch789
Default hard to steer when slowing down or in parked
what causes this help me out is it the power steering pump or something else help me out
Old Jun 30, 2010 | 03:45 PM
CappinHoff's Avatar
CappinHoff
It sounds like the power steering. Check the fluid and the belt.
Old Jun 30, 2010 | 03:51 PM
ryan0714's Avatar
ryan0714
+1 thats what i would say
Old Jun 30, 2010 | 04:05 PM
deathwatch789
im not loosing any fluid and the belts fine fluid does seem old
Old Jun 30, 2010 | 04:20 PM
ryan0714's Avatar
ryan0714
if ur fluid level is fine you should still be gettin the pressure from the pump though. hmmm...
Old Jun 30, 2010 | 04:26 PM
CappinHoff's Avatar
CappinHoff
Does it make any sounds? Is it hard to turn both directions or just one?
Old Jun 30, 2010 | 05:09 PM
deathwatch789
its hard to turn both and it makes a slight sound
Old Jun 30, 2010 | 05:14 PM
CappinHoff's Avatar
CappinHoff
If there is no play in the belt and your fluid lvl is ok. Your pump might be going out. I would try to drain the fluid and refill with new just to make sure.
Old Jun 30, 2010 | 09:05 PM
dhvaughan's Avatar
dhvaughan
replace the fluid by sucking out the old with a turkey baster or gear oil hand pump.
with engine off, pump it out, then refill. start engine and run it a little while, then turn off engine and repeat the cycle 2 or 3 or 4 times. this will take about a quart or so and get out almost all the old fluid.
Old Jul 11, 2010 | 09:05 PM
babyluvsmydodge's Avatar
babyluvsmydodge
got a 2005 with the same problem. i put in a rebuilt pump and it didnt help! i cant figure it out ethr. anybody know?
