rims too wide, rubbing, spacers??
Old Jul 6, 2010 | 02:42 PM
Nortzy's Avatar
Nortzy
Default rims too wide, rubbing, spacers??
i just bought a set of old 80's style dodge rims from a ram charger. the rims are too wide to fit, they are rubbing my tie rod end. should i get spacers? or should i machine the rim a little. and if so, what spacers? how expensive? it's a 2wd ram 1500, and i really like the rims
Old Jul 6, 2010 | 03:24 PM
dodgeram07's Avatar
dodgeram07
i take it they are 15in rims?
Old Jul 6, 2010 | 04:54 PM
Nortzy's Avatar
Nortzy
yeah, the 80's style turbo rims, 15in., they are on 31x10.50 a/t tires. the tires dont rub, the rims just barely rub on the tie rod end.
Old Jul 6, 2010 | 04:59 PM
Augiedoggy's Avatar
Augiedoggy
I guess I would search ebay for them to see how much they are (spacers) since the backspacing is different from 80's ramchargers...I have 15" rims and they work fine with correct backspacing...
Old Jul 6, 2010 | 05:43 PM
Nortzy's Avatar
Nortzy
Well priced on Summit its 150 for a kit, or 56 ea.
Old Jul 6, 2010 | 06:06 PM
Gord.'s Avatar
Gord.
If it's just a tiny bit of rub you could grind the TRE a little bit but be extremely careful. I did this on my old jimmy, just had to take down the edge a bit for it to clear the rim. Taking much material off can compromise the strength of the joint but it can be done.
Gord.
Old Jul 6, 2010 | 06:27 PM
TheBigRedOne's Avatar
TheBigRedOne
PLEASE, for the love of God, DO NOT USE WHEEL SPACERS ON A TRUCK. It's a recipe for disaster. It puts you and everyone else on the road in danger.
Old Jul 6, 2010 | 06:45 PM
dhvaughan's Avatar
dhvaughan
how much are we talking about grinding off the tie rod ? maybe 1/8 or 3/16? that'd probably be ok. i'd grind the corner of a tie rod before i would the wheel. +1 on "damn a spacer".
Old Jul 6, 2010 | 07:41 PM
PurplDodge's Avatar
PurplDodge
X10!!!! Pick up August's issue of Off-Road magazine (Yes, the one with the sweet Dodge on the Front!!!). They have an article showing the damage of what happens when you put spacers and stupid large tires on a truck.
Put the wheels you bought on Craigslist and buy some that fit.
Old Jul 6, 2010 | 08:26 PM
redheadhunter21's Avatar
redheadhunter21
You should be able to grind a little off the tierod ends and be good easiest and safest way
