2001 ram 1500 with 2500 v10 front springs tire size question
Old Jul 7, 2010 | 11:19 PM
redneck_ram's Avatar
redneck_ram
Default 2001 ram 1500 with 2500 v10 front springs tire size question
hi all i installed 2500 v10/diesel springs on the front end of my 1500 4x4. my question is can i sqeeze 35/12.50/15 tires/rims in there with the 2 inches of lift the springs gave me? will i have tire rub or will everything be ok? my neighbor has a set and i want to buy them. any help is appreciated thanks.
Old Jul 7, 2010 | 11:57 PM
35's with the more than likely 3.55 gears will not exactly be a good combination.... unless you drive around in four low a lot.......
As for "will it fit". Maybe. They will more than likely rub at full lock, and also possibly on the rearmost part of the bumper, and probably on the plastic inner fender well in the back.
Old Jul 8, 2010 | 01:41 AM
redheadhunter21's Avatar
redheadhunter21
Ask your neighbor if you can test fit them, only for sure way, I know some of the Offroad edition people run 35's with minimal rubbing at full turn, so you should be in close to the same catagory
Old Jul 8, 2010 | 02:15 AM
99dodge318's Avatar
99dodge318
also they will rub on the front control arms
Old Jul 8, 2010 | 02:22 AM
redheadhunter21
No offense 99dodge but it depends on what rims the tires are mounted on and their backspacing
Old Jul 8, 2010 | 10:28 AM
redneck_ram
what do you mean by 3.55 gears not being a good combination? will it destroy my transmission? any help is appreciated. thanks.
Old Jul 8, 2010 | 11:08 AM
It is certainly going to increase the workload on your trans..... All the calculators I have used wanted 4.56 gears with 35's, to maintain the same final drive ratio as the truck came with stock. (which, one could argue was a bit off to begin with, in the interest of fuel economy.......)
What that means is, your trans is going to get hotter. Heat kills transmissions..... the torque converters are weak to begin with, and this will put additional strain on it. Not to mention you are going to have to step on the gas pretty hard just to get the truck rolling, due to heavier tires, and the reduced final drive ratio larger diameter tires are going to inflict on you. What you have, is two factors contributing to generating a bunch more heat.
Will it unquestionably kill your trans? I don't have an answer there. But, just looking at it, going to 35's without regearing, will most certainly shorten the life of your trans.
Old Jul 21, 2010 | 10:07 AM
redneck_ram
well i got the 35's on and i have to remove my side steps/running boards because the tires rub them like crazy during a turn. after those are off i should be good.
Old Jul 21, 2010 | 01:12 PM
How does it drive/accelerate with those meats?
Old Jul 22, 2010 | 08:37 AM
redneck_ram
drivability and acceleration seems to be as normal as normal can get. the tires are wicked loud and you can feel the cleats when coming to a stop but other than that theyre great.
