numerous cylinder misfires
Old Jul 9, 2010 | 11:32 AM
  #21
aim4squirrels's Avatar
aim4squirrels
There have been numerous posts on the forum for and against the autolites. My truck didn't like them either, but the older models seem to like them better. I know there was a change in the stock plug snout length at some point in the 2nd gen life cycle.
Old Jul 9, 2010 | 11:42 AM
  #22
Gary-L's Avatar
Gary-L
Veteran: Navy
My 1997 didn't like the Autolites.
Old Jul 9, 2010 | 12:21 PM
  #23
cmckenna's Avatar
cmckenna
I ran 7500 miles on them -So Cal to NY and back on Autolites and had zero issues gapped according to spec. The only thing was, the performance was not there. Normally, I always ran NGKs and, never had an issue with them. I was testing the Autolites out to see if they were any better than NGKs or not and, while they worked fine, (no misfires), the feel was just not the same as the NGKs. However, as soon as I got back to So Cal, I installed the Pulstars. After using all three- I'll never run another plug in my Dodge other than Pulstars. I like the feel and how it runs with them over conventional plugs.
CM
Old Jul 9, 2010 | 04:34 PM
  #24
aim4squirrels
Those are pretty expensive plugs there, but then again, so was the MSD box I bought.
But I swear it idles and responds better with that box on than off.
EDIT: just saw on the website the price has gone down considerably, and they state they can be used with the MSD box, hmm....
Old Jul 10, 2010 | 02:33 PM
  #25
1999dodgeram's Avatar
1999dodgeram
hey so the plugs i put in are ngk iridium ix 2667. they're gapped at .025 because the performance shop i bought them at said to gap at .010 less then the book. but my truck had this issue BEFORE AND AFTER changing the plugs and the were champions in there before
Old Jul 10, 2010 | 02:41 PM
  #26
aim4squirrels
Go back to the stock .040 and report back. Do not break the iridium tips, pry back on the ground strap only.
Old Jul 10, 2010 | 03:42 PM
  #27
cmckenna's Avatar
cmckenna
I know for my truck, OEM gap is to be set to .035". Which years / engine models spec out 40 mils? Again, just asking in attempt to keep building my own library of knowledge.
CM
Old Jul 10, 2010 | 04:25 PM
  #28
aim4squirrels
2001 is definitely .040, I believe 2000 was as well, but now I'm not 100% as I thought the change happened on the 98 model year.
Old Jul 10, 2010 | 04:33 PM
  #29
Mowhawk's Avatar
Mowhawk
00 an 01 are gapped to .040, and I do believe that the change happend in 98 as well.
Squirrels, you have an 01 correct? If so, I have a 00 so those two years are a definite 40 mils.
Old Jul 10, 2010 | 05:06 PM
  #30
aim4squirrels
Yes, mine's a 5.2L 2001.
