numerous cylinder misfires
Old Jul 8, 2010 | 12:31 AM
1999dodgeram's Avatar
1999dodgeram
Default numerous cylinder misfires
hey so i have a cylinder misfire and it varies which ones they are. i can feel it on the highway it will be like a jerk or stumble. i can clear the codes and it the check engine will come on and it will be different cylinders maybe one the same. i also had fault code p0340. so i have changed the plugs, wires, cap, rotor and camshaft sensor. p0340 went away (camshaft sensor code) but still have misfires. anyone have any idea what this may be? oh i also have a small exhaust leak where my header meets the y pipe flange. would this have anything to do with it?
Old Jul 8, 2010 | 12:51 AM
J415's Avatar
J415
If you can feel it on the highway (faster MPH) then that would lead me to believe you have a clogged cat.
Old Jul 8, 2010 | 01:01 AM
1999dodgeram
hmm i dont think that would be it, i just switched to a magnaflow y pipe and cat less then a year ago. and it doesnt stumble constantly it will do it then maybe a few minutes later, then 15 mins later then like 2 mins later etc
Old Jul 8, 2010 | 01:08 AM
army_greywolf's Avatar
army_greywolf
Weak spark. Try closing your plug gap .010 and see if it gets better. Since I was thinking this through have you checked your plenum yet?
Old Jul 8, 2010 | 01:14 AM
1999dodgeram
well i added an msd ignition coil, msd plug wires, msd 6a ignition box, and changed the plugs to ngk cold plugs so with the msd i dont think weak spark would be the problem. and nope havent checked it, how would i go about checking it and how hard is it to change?
Old Jul 8, 2010 | 01:38 AM
1999dodgeram
the misfires were previous to adding all those parts and continue afterwards. i also have a superchip, throttle body spacer, high flow y pipe and cat, cat back exhaust, cai, centre force clutch and run premium fuel if any of that would make a difference?
Old Jul 8, 2010 | 12:13 PM
Check your fuel pressure.
Maybe try some fuel injector cleaner. (seafoam?)
There is a TSB (technical service bulletin) on plug wire routing, but, as you have replaced the stock wires, I am not sure if that would even apply.......
Throttle body spacer is a waste of money our the dodge trucks. Does nothing.
If you put it back to the stock tune, does it still do it?
Old Jul 8, 2010 | 12:47 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Dirty or broken Camshaft Sensor (located in the distributor) can cause this issue.
And yes, even though the "Y" pipe was installed over a year ago, a clogged cat could be an issue, which means that the cat is faulty or there's a problem with the emission system of your truck.
Old Jul 8, 2010 | 07:19 PM
1999dodgeram
hmm well i changed the camshaft sensor yesterday and its still doing it, how would i go about checking the fuel pressure and if it is a fuel pressure issue would that mean changing the pump? abd i'll try changing the superchip tuning back to stock and see what happens
Old Jul 8, 2010 | 07:28 PM
1999dodgeram
if it is fuel pressure would putting an inline fuel pump be enough to boost the pressure?
