Tire Help Question
Old Jul 10, 2010 | 10:13 AM
JediSky671's Avatar
JediSky671
Default Tire Help Question
Hey guys just wondering what's the max tire width I can put on my stock 1998 Ram 16x7 rim.I was thinking a maybe 31x10.50 on my stock rim or something like that.Would that work and if so what's the widest to go on my 16x7 stock?
Old Jul 10, 2010 | 01:31 PM
ryan0714's Avatar
ryan0714
yes 10.5 will fit, but its pushin it, thats as big as you gonna wanna go on that rim. basically, take ur rim width + 3" and thats all the max width tire you wanna go.
Old Jul 10, 2010 | 02:39 PM
EHS22's Avatar
EHS22
i run 285/75/16 size tires on my 16x7 stock rims.
Old Jul 10, 2010 | 02:53 PM
redheadhunter21's Avatar
redheadhunter21
I have seen up to a 305 ran on 7 inch rims, max I would put is 285 though which is about 11.5 wide.
My track rims are only 6 inches wide and I have 275/60/15 inch tires on them and even though they are a little round, after all the spinning and abuse I have put them through no problems, but they were a b*tch to put on
All in all the 10.5's are no problem
Old Jul 10, 2010 | 03:03 PM
I am just wondering if I could go to the junkyard, and pick up some wider wheels off of a different truck? I have a 96 2500, so, eight lug..... anyone have a clue if one of the other manufacturers have the same bolt pattern with a slightly wider wheel?
Old Jul 10, 2010 | 03:48 PM
redheadhunter21
IIRC the fords have the same bolt pattern for a couple of years, go here and look it up http://www.roadkillcustoms.com/hot-r...e-Database.asp
Old Jul 10, 2010 | 04:22 PM
Thank You. I want to put some wider tires on the truck when the time comes... (income tax...) but, I really don't want to put 11+ inch wide tires on my 6.5 inch rims... Whose brilliant idea was it to go with such a skinny rim??
Old Jul 10, 2010 | 07:33 PM
Aubrey's Avatar
Aubrey
I have 305s on mine.
Old Jul 10, 2010 | 08:06 PM
JediSky671's Avatar
JediSky671
I was also told that at stock height my I could run 32"s.Is that true I have no lift and my truck is 4x2.What would a 285 and 305 be in inches?What is the equivalent for a 32"?is it the 285 or the 305?How wide is a 285?
Old Jul 10, 2010 | 09:35 PM
redheadhunter21
Yea a 32 on a 2wd is about it, when dealing with metric sizes the first number is the width, then the next number is the aspect ratio and the last is the rim size....a 285/75/16 which done in standard is 33x11.3x16
That is a little to big for a 2wd, you could run it but you would have to deal with rubbing or do a little work with the plastic inner fender, a coil spacer could solve this for cheap, or just stick with a 265/75/16 which done in standard is 32x10.5x16
