98 ram 2500 is misfiring in cylinders 2 and 3
Old Jul 11, 2010 | 03:24 AM
bulldozer2500's Avatar
bulldozer2500
Default 98 ram 2500 is misfiring in cylinders 2 and 3
just wondering if ne one has ne suggestion i already chaged all the plugs but its still missing and it idles a little rough just trying to figure out what the cause would be and if ne one else has had tht problem
Old Jul 11, 2010 | 10:07 AM
What do your plug wires/cap/rotor look like?
Are you aware of the Technical service bulletin on plug wire routing? (available in the FAQ section here.)
How many miles on your truck?
If the ignition parts are in good shape, I would recommend doing a compression test, and see what the numbers look like. The problem cylinders are on opposite banks of the engine.... so, compression numbers should be interesting to see.
