steering
Old Jul 11, 2010 | 10:19 PM
Disconnects? Where did ya get 'em?
Old Jul 11, 2010 | 10:28 PM
dsertdog56's Avatar
dsertdog56
I adapted a set of warrior products from a jeep. Pics are in my gallery.
I apologise to the OP for 'jacking this post. I have yet to adjust my box, a suprise considering the abuse it's recieved and the mileage.
The last "slop" I encountered was due to a worn RH tie rod end/drag link. Replacing the entire steering system with 1 ton "crossover" steering solved the issue. You don't need to do that, but it improved the overall feel and "input" from the wheel.
I'd want to find out why your steering wheel is cocked. Did you recently lift your truck?. I'd have your toe-in checked and your wheel centered by a competent shop
Old Jul 12, 2010 | 04:37 AM
TheBigRedOne's Avatar
TheBigRedOne
You do any towing with your truck? How does it handle without the sway bar? (I am considering yanking mine, to get a bit more flex.....)
Hells yes I tow with it, It's what I use to get my Expedition to the desert! It handles just fine.
