4wd problem
Old Jul 16, 2010 | 07:28 PM
97tn4x4's Avatar
97tn4x4
Default 4wd problem
I know there are tons of threads on this but I've searched about all I can lol. It started when my transfer case started making a loud popping noise. I was told it was the chain so I replaced it today. Put it back together and now the 4wd isn't engaging. The transfer case is working cause the front driveshaft is turning. I can even feel the difference when it's in 4lo but the front wheels don't pull. It worked before so I'm kinda lost.
Old Jul 16, 2010 | 10:56 PM
Did you plug the vacuum lines into the switch on the transfer case?
Old Jul 17, 2010 | 02:22 AM
99dodge318's Avatar
99dodge318
mine did this when i first got it. it was a bad 4wd selector switch. bought it at napa for $13
Old Jul 17, 2010 | 06:01 AM
ryan0714's Avatar
ryan0714
http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Jul 17, 2010 | 02:21 PM
97tn4x4's Avatar
97tn4x4
Yes I plugged the switched in. I even tried switching the actuator switch with my other one. I think I'm just going to buy a posi lok kit and do away with it all. Are there any down falls to it? Where did everyone who has one run they're cable
Old Jul 17, 2010 | 09:02 PM
Aubrey's Avatar
Aubrey
I followed the instructions on where to install mine with one slight change. I didn't run mine into the wheel well.
Downside? It needs to be adjusted properly or it can be tough to engage and disengage.
Old Jul 18, 2010 | 06:11 AM
ryan0714's Avatar
ryan0714
sounds like its worth it to get rid of the vacuum system
Old Jul 19, 2010 | 01:05 AM
97tn4x4's Avatar
97tn4x4
So I take it all the info on how to adjust it and everything is in the instructions? Where did you run yours?
Old Jul 19, 2010 | 10:43 AM
ryan0714's Avatar
ryan0714
yea it says in the instructions on how to adjust it, you gotta back off the jamnut on the outside of the housing, and make sure that the e ring or whatever is meeting up with the side of the inside housing when your engage-ing the cable and if not then un thread the cable a little until it does then run the jamnut back down securly.
