hub nut size ?
Both are right.
ON 4WD Though It's actually 43mm, but most here use one of the following.
I used a 1 3/4...
1 11/16 may need to be tapped on it's a little snug.
Is it 2wd or 4wd?
Welcome to the forum.
I used a 1 3/4...
Is it 2wd or 4wd?
1 11/16 needs to be put on, then rotated a little bit if it doesn't go on all the way and tried again, and again until it goes all the way on the nut.
That socket is 6$ at tractor supply if you have one near you.
Yea, 1 11/16, $15-$20 at sears. But as sheriff said, just needs to be rotated to get the socket to fit over the nut.
Trending Topics
On my 01' Ram 1500 2WD the hub nut size is 1-3/8".35mm will also work if you have only metric sizes.Socket fit snug and I was able to torque to spec without any issues.
Andy.
