Rough Idle
Old Jul 18, 2010 | 12:08 PM
2k10HemiRam's Avatar
2k10HemiRam
Default Rough Idle
Yay, I replaced my IAC, IAT, MAP, and TPS on Friday and the test drive after I installed everything fixed my problem, during that drive at least. Later in the day my rough idle came back to haunt me. So after doing some "light" reading on here last night, I came up with a list of things I'm going to check and hope I find/fix the cause of the problem. Here in a little bit I'll be going out and I'm going to:
change plugs/wires...I've had autolites and msd 8.5 superconductors sitting for awhile
inspect/clean/maybe replace upstream co2 sensor
seafoam engine...the problem started not to long after I switched to the FI AirGap so maybe I got something in there?
Oil Change
Wet/Dry compression test...I'd have to get the tester but I'm hoping if the other things don't fix it that this test goes good cause I really can't afford to dig into the engine yet to fix the problem.
