Key Dance Code...Urgent
Alright fellas, I got a quick one for you guys. I recently got a CEL. I did the key dance and it gave me 1231 I'm outta town and I also let my brother in law barrow my code reader so I can't check it. I get p0441 more or less every 200 miles or so. Even though it might be just that, I just wanna be sure. Thanks again fellas.
So code 1231 (key dance mode) is equal to getting 0441 via a code reader? Thanks for the reply.
The closest thing I could find to a 1231 was this, but the page said it was for the 02-08 models. Might be the same, might not.
P1231 Injector Circuit Cylinder 4 Intermittent
Found it here: http://www.allpar.com/fix/computer-codes.html
No..... two separate problems, I couldn't find the 1231, although, I see someone else did. Just the injector connector on the cylinder in question.
I found out that the codes I got (12 31) were "Direct battery to PCM disconnected within the last 50 ignition key-on cycles" and "Problem with canister purge solenoid circuit" so the 31 key dance code is equal to a P0441. Thanks again for the help fellas.
