running problems
Old Jul 19, 2010 | 10:22 PM
dodgeman52's Avatar
dodgeman52
Default running problems
when i go to start my truck in the mornings it will surge for the first 1 minute it is runnning then after that i runs fine. i have done the plenum,full tune up,fixed my header leak, and fixed the cracked pvc vavle hose and nothing has fixed my problems. i am running out of ideas? any suggestions? it has no check engine lights
Old Jul 19, 2010 | 10:47 PM
On a cold start, the engine will run up to 1200-1000 RPM, and then slowly settle down to 'normal' idle. Is that what its doing?
Old Jul 19, 2010 | 10:54 PM
dodgeman52's Avatar
dodgeman52
no it will go to 1000 rpm and then sit there and surge for the a minute or two and then it will slowly settle down after it is done surging. i have cleaned the iac and that didnt help. it also has a hollow cat and i dont know if that will cause it to run like that when it is cold
Old Jul 19, 2010 | 10:56 PM
Sounds like maybe a vacuum leak. Does it act like it is "hunting" for the RPM it really wants to be running at?
Old Jul 19, 2010 | 11:03 PM
dodgeman52's Avatar
dodgeman52
yea kinda but after a minute or two it runs perfects and the idle is steady
Old Jul 19, 2010 | 11:54 PM
Hmmmm.... Might wanna do a search, and see if you can find any more information on folks that used the E3 plugs, I seem to remember a few members having issues with them, but, I really don't think that is your issue.... not even sure it would be a contributing factor....
If it only does it at cold start....... try having a look at fuel pressure first thing in the morning.... I know, its a reach......
Old Jul 20, 2010 | 08:06 AM
dodgeman52's Avatar
dodgeman52
i checked the fuel pressure while it was runnning and the fuel pressure stayed the same even when the truck started surging.
Old Jul 20, 2010 | 11:37 AM
Might try cleaning the throttle body, including the IAC passages.....
Old Jul 20, 2010 | 02:39 PM
dodgeman52's Avatar
dodgeman52
i did all that when i had my intake off a few thousand miles ago.
Old Jul 20, 2010 | 02:45 PM
How long has it been doing this? Did it start before or after doing the intake work?
Have you checked for vacuum leaks? (doesn't sound like that either though...... )
