Tightening Compression Tester Inside Heat Shields
Old Jul 20, 2010 | 04:43 PM
chrscott's Avatar
chrscott
Default Tightening Compression Tester Inside Heat Shields
Does anybody have any tips or tricks for tightening a compression tester properly on a Magnum Engine?
I find the spark plug wire boot heat shields that are attached to the cylinder head, get in my way of properly hand tightening my compression tester. I think this may lead to inaccurate compression tests.
When I do a compression test on my truck (2001 5.9 gas), I tighten my compression tester by the piece of hose that connects the gauge to the fitting, because the heat shields stop me from "handling" the compresstion tester fitting itself.
But sometimes I can only get it so tight before the hose starts to spin on the fitting (and the fitting stops tightening into the cylinder head).
Once I used needle nose pliers to reach down into the heat shield and back out a stuck comp tester.
Does anyone have any tips or tricks to properly tighten a compression tester inside the heat shields?
Any special tools available for this job?
Thanks,
Chris
Old Jul 20, 2010 | 06:19 PM
charlie1935's Avatar
charlie1935
Get rid of the heat shields.
Old Jul 20, 2010 | 07:25 PM
dhvaughan's Avatar
dhvaughan
+1. grab those mother ****ers with a big pair of pliers and shake them back and forth until they come out, then throw them as far as you can....
they lead to difficult plug changes, possibly stripped threads, dirt into cylinder, etc. i got rid of mine about 4 years ago with no ill effects.
Old Jul 20, 2010 | 07:30 PM
Maxx_Magnum's Avatar
Maxx_Magnum
hmmm, if I'd known this a few days ago, I might have pulled mine out too. I thought they were better off stayin in there
Old Jul 20, 2010 | 08:29 PM
seabass202's Avatar
seabass202
yeah, I like the fact I have those heat shields. you could try lubricating the threads in the head along with the O-ring on the end of the compression tester. also is there a way to stop the hose from spinning without tightening the threaded portion of the gauge? maybe a zip tie or small section of hose slipped over the union? maybe some heat shrink? maybe all these things in conjunction could get you an accurate reading without s-canning the heat shields. good luck!
Old Jul 20, 2010 | 08:35 PM
UnregisteredUser's Avatar
UnregisteredUser
The pliers-type spark plug wire removers will work just fine.
Old Jul 20, 2010 | 08:47 PM
seabass202's Avatar
seabass202
to tighten the compression gauge or to remove the heat shields?
Old Jul 20, 2010 | 09:36 PM
UnregisteredUser
To tighten the compression tester.
Old Jul 21, 2010 | 10:30 AM
chrscott's Avatar
chrscott
Hey Guys,
Thanks for the tips, much appreciated. I think that I will leave the heat shields in there. I seem to remember the FSM saying not to remove them.
I like the ideas of lubricating the fitting and o-ring, and also using the spark plug boot puller to tighten the fitting. I will give that a try.
Is there any chance that a spark plug wire could arc to the heat shield? Has anyone encountered this?
Thanks again,
Chris
Old Jul 21, 2010 | 08:27 PM
98BlueSport's Avatar
98BlueSport
I tried getting them heatsheilds off last night and they wouldnt come off at all. i twisted the hell outa the one, and it just looks like a spark plug blew up inside of there
