Trans Help...
Old Jul 20, 2010 | 09:36 PM
CaliberGSD's Avatar
CaliberGSD
Default Trans Help...
just bought a 98 dodge ram 2wheel .... 130k .... guy said trans replaced at 90...anyways.... drives smooth ..... shifts really smooth.... but truck is making this rattle noise that seems to be coming from the trans.... when you have in idle or reverse it gets louder... tried to record but noise of engine washes it out... like i said it runs perfect but it makes a horrible rattle noise that sometime goes away but most of the time is there....
Old Jul 20, 2010 | 09:37 PM
Pull the inspection cover off of the bellhousing, and check the flex plate, see if it is cracked.
And welcome to DF!
Old Jul 20, 2010 | 09:38 PM
CaliberGSD's Avatar
CaliberGSD
and it may just be getting louder because i think it is.... lol but its so irritating..
Old Jul 20, 2010 | 09:40 PM
CaliberGSD's Avatar
CaliberGSD
thanks for the welcome.... whats involved with removing the bell housing.... done some simple work on cars but nothing like that but would love to lean and do... maybe a site you can recommend that shows it
Old Jul 20, 2010 | 09:45 PM
RamSport97's Avatar
RamSport97
Just remove the starter, and then there is like 5 or so 1/2" or 9/16" bolts holding the inspection cover on.
Old Jul 21, 2010 | 09:16 PM
DODGEIT105's Avatar
DODGEIT105
The flexplate bolts that hold the torque converter on could also be looseing.
Old Jul 22, 2010 | 07:35 PM
seabass202's Avatar
seabass202
could be the cat.
Old Aug 5, 2010 | 09:54 PM
CaliberGSD's Avatar
CaliberGSD
havent checked the touqe cov yet but not not cat ... just had that replaced because it was bad but it not a noise like that....
