all 8 cylinders misfiring at once help!!!!!!!!!
Old Jul 27, 2010 | 02:08 AM
cmckenna's Avatar
cmckenna
Originally Posted by mistywarnock
thanks i will try one at a time that way i know what it actually was and then i will repost when i know.
There you go, that's the way to test. Factor out each one at a time. Good man.
CM
Old Jul 27, 2010 | 02:13 AM
JRob238's Avatar
JRob238
Another thing you could do if you wanted to test out the sensors it touch an ohm meter to them to make sure they are showing the correct amount of resistance. ten bucks for an ohm meter is better than 90 bucks for a CPS that wasnt bad.
