Upper bal joint won’t stay pressed in
Old Jul 25, 2010 | 02:05 PM
oakleytw's Avatar
oakleytw
Default Upper bal joint won’t stay pressed in
About 2 months ago I pout new upper and lower bal joints no my driver side 97 2wd 1500. The other day my upper ball joint fell out of the a arm I pressed it back in 2 times and it keeps popping right back out. Can any buddy give me a tip to what I should do from here!
thanks, Tom
Old Jul 25, 2010 | 02:52 PM
dodgeram07's Avatar
dodgeram07
thats weird seeing that the upper is beening pulled down
what kind of joints did you use i know that sum people said that autozone were to small
i put in moog i few years ago with no problems
you have a welder? tach a few spots
Old Jul 25, 2010 | 03:24 PM
oakleytw's Avatar
oakleytw
I bought the murrays/oreileys store brand with life time warranty. Im going to take it back up there. I have a welder but its a good 20 mins away at my parents. And my truck is obviously not driveable. I'm thinking about using an air hammer to try and bend the a arm a little.
Old Jul 25, 2010 | 09:29 PM
JackJ's Avatar
JackJ
the ones I bought from Oriely, were to small for me. I had the same problem.
Old Dec 6, 2010 | 02:38 AM
oakleytw's Avatar
oakleytw
Welding them in place ended up being my only answer. I had no choice at the time, Monday morning was coming fast. Its been a couple months now and there still holding strong…. But there going no were!
Old Dec 6, 2010 | 06:50 AM
95RAM360's Avatar
95RAM360
just throwing a shot in the dark.......did you grease them right up? if not maybe that will hold them in place....
Old Dec 6, 2010 | 09:09 AM
TheBigRedOne's Avatar
TheBigRedOne
So press it back in, and drive carefully over there.
Old Dec 6, 2010 | 11:59 AM
justfrfun's Avatar
justfrfun
Default never had that happen.....
Wow. thats crazy. We only use moog here maby thats why i never had a problem.
Old Dec 6, 2010 | 01:54 PM
aim4squirrels's Avatar
aim4squirrels
If a ball joint falls out, it's too small. Period.
Old Dec 6, 2010 | 02:50 PM
Or, the control arm hole has been stretched out..... Seen that happen before too.
