valve cover grommet
Old Jul 26, 2010 | 12:46 AM
dodgeram07's Avatar
dodgeram07
Default valve cover grommet
is anybody running to two stand alone crank vent breathers? if so were did you get the valve cover grommet to replace the pcv grommet
wanting to delete the pvc and replace with a breather just like the of side
anythoughts
Old Jul 26, 2010 | 07:00 AM
dhvaughan's Avatar
dhvaughan
its really not a good idea to delete the pvc, as its job is to extract oil and gas blow-by vapors. better to have one breather and one pvc.
i replaced my grommets and i might have gotten one of them at autozone but i had to go to the dealer for at least one, maybe both. they weren't too expensive, a few bucks.
Old Jul 26, 2010 | 09:03 AM
PCV needs to be there. It keeps the assorted blowby contaminants out of your oil. (well, ok, it tries, at least...) not to mention, drawing the slight vacuum on the crankcase also helps piston rings seal.
