popping under drivers side?
Old Jul 27, 2010 | 08:36 PM
mrfarrell's Avatar
mrfarrell
do you have a body or suspension lift?
Old Jul 27, 2010 | 08:37 PM
dhvaughan's Avatar
dhvaughan
loose lower shock bolt. torque to about 110 pounds.
Old Jul 27, 2010 | 08:54 PM
RamSport97's Avatar
RamSport97
+1, I had this problem. Also make sure the nuts on top are tight as well.
Old Jul 27, 2010 | 09:28 PM
penfold's Avatar
penfold
x3 for loose shock bolts.
had same issue
Old Jul 28, 2010 | 01:49 AM
JRob238's Avatar
JRob238
looks like i will be checking the shock bolts!
the control arm bushings where solid.
no lift at all straight stocker.
Old Jul 28, 2010 | 08:11 AM
aim4squirrels's Avatar
aim4squirrels
There was an old TSB on the cab mounts of club/full cabs popping. It was a defect from the factory.
I agree that the most likely culprit is the shock bolts, but don't discount the cab mounts just yet.
