a/c compressor smoking
Old Jul 30, 2010 | 02:55 PM
omanalansan's Avatar
omanalansan
Default a/c compressor smoking
Well it looks like i need to replace my compressor. i have 3 questions
1. I've read that you should replace the accumulator as well, anything i need to replace?
2. Has anyone ordered a compressor on Ebay, i see one for $109? I just emailed the company and they said teh compressor leaves the manufactouer dry.
3. is there a DIY Write up on this? just want to make sure i'm crossing my t's and dotting my i's.
I've already replaced the evaporator.
thanks
Oscar
Old Jul 30, 2010 | 06:02 PM
FarmBoy428's Avatar
FarmBoy428
When your in the cab with your a/c on is it blowing smoke? Because thats not smoke, its moisture. And do your floor boards get a little wet, by the pedals, and the upper floor on the passenger side?
Old Jul 30, 2010 | 07:36 PM
omanalansan
No smoking from the compressor (inside the engine) burning smell
Old Jul 30, 2010 | 07:41 PM
Compressor is probably seized, and when you turn on the A/C, the belt can't turn it, so the belt smokes. Should make some rude noises as well.
Shut the truck off, and let everything cool. Open the hood, and try and turn the center section of the compressor pulley. My guess is, you won't be able to. Time for a new compressor. In the meantime, don't use the A/C, and unplug the compressor clutch from the harness connector.
Old Jul 30, 2010 | 08:02 PM
omanalansan
Good idea about unplugging the wire harness.
