PCV valve delete
Old Aug 1, 2010 | 10:13 PM
BigRedRam95's Avatar
BigRedRam95
this is the one i bought I got
Old Aug 1, 2010 | 11:11 PM
SnowFox's Avatar
SnowFox
that looks like it holds about a quart....
thats a lot.....
Old Aug 2, 2010 | 05:19 AM
bigslick050's Avatar
bigslick050
Looks like a nice upgrade RedRam! Be sure to give us some before and after pics! Or even a DIY would be nice...really curious to see how that turns out for ya. Looks really cool
Old Aug 2, 2010 | 08:49 AM
aim4squirrels's Avatar
aim4squirrels
You can build a catch can out of a simple air compressor filter purchased from the local hardware store. Lowes, or Home depot for less than $20.00. They are completely unnecessary for a vehicle that is not running a turbo or supercharger. The amount if oil that travels thru the PCV is not performance hindering.
If you do find tha the catch can is actually catching significant amounts of oil, I'd wager you either have a bad PCV valve, overfilled the crankcase with oil, or worse, your piston rings are allowing excessive blowby, which means a motor rebuild is in your future
Old Aug 2, 2010 | 10:07 AM
UnregisteredUser's Avatar
UnregisteredUser
I'm with the destroyer of squirrels on this one, for what little it matters. A properly functioning PCV system on a sound engine isn't going to put much oil at all into the intake manifold.
Just replace the valve at each tune-up and be done with it.
Old Aug 2, 2010 | 10:21 AM
BigRedRam95
Did all you guys just put a breather on the back of the left valve pan where it has a hose theat goes to the intake? If so how do I block off the place for it on my intake tube?
Old Aug 2, 2010 | 10:32 AM
revvhigh's Avatar
revvhigh
Originally Posted by pcfixerpro
haha... and after a quick search.. aparently this is not a good idea.
Could you share your learnings? This idea also appeals to me and I'd like to hear the pro's and con's.
Old Aug 2, 2010 | 11:17 AM
aim4squirrels
Most guys that use the stand alone breather do so because their air hat does not have a fresh air intake provision for the crankcase. If you've got one, use it and save the dinero.
Attempting to delete the PCV system inhibits the engine from expelling blowby gases from the crankcase. When a cylinder fires, gases from combustion leak past the piston rings into the crankcase. These gases are exhaust fumes that can corrode the engines internals and dirty the oil with hydrocarbons quickly, preventing the oil from doing its job effectively. The PCV system creates an "air current" through the crankcase that brings fresh air in from the vent tube on the air box, passes it thru the crankcase and the vacuum in the intake manifold pulls the gases out thru the PCV valve when enough pressure from inside the crankcase + engine vacuum overcomes the pintle in the PCV valve. The gases are then recycled in the combustion process. For max effciency, the fresh air tube should be on the opposite side of the engine from the PCV valve.
The cons far outweigh the pros of deleting the PCV system.
Old Aug 2, 2010 | 11:37 AM
BigRedRam95
The only reason I asked is because I took off my intake tube a few days ago and noticed a little tiny bit of oil in the tube it looks like someone opened a new bottle of oil and but some in the intake its not black. And if you say that hose sucks air into the crank case where is the oil comming from?
Old Aug 2, 2010 | 11:54 AM
There will be some oil vapor sucked in as well. If the PCV valve is not functioning properly, it can actually suck in a fair bit of oil. Pull the valve, and shake it, if it doesn't rattle, it is stuck, and therefore, not doing its job. The valve is supposed to have a specific flow rate, if it is stuck open, the flow rate is significantly higher than what it should be, and you get oil in the intake. Simply replacing it will solve that. (and it's cheap.) Aftermarket valves tend to vary (sometimes dramatically) from the factory specified flow rate. The dealer part is generally much closer to what the engineers had in mind.
PCV system also serves to aid with ring seal. Drawing a slight vacuum on the crankcase helps them seat better. (no clue why, just the way it works....)
