Need help!! Tapping noise
Old Aug 3, 2010 | 09:06 AM
79jon's Avatar
79jon
Thanks for the reply's, I appreciate it. I think ive got no other choice than to pull the pan clean the sludge out. I was looking underneath and it didnt look to hard from what I could see. Looks like I might be able to get away with pulling the pan without lifting the motor right? Has anyone been able to do that? I will def replace the oil pump for sure as well as the screen. I was looking at autozone.com and the screen was only 16.99 so instead of trying to clean the inside of the tube out ill just get a new one. I'm wondering while im at it, if I should go ahead and get some valve cover gaskets and check the rockers just in case. Maybe clean them and the push rods up.
Old Aug 3, 2010 | 09:52 AM
dodgeman52's Avatar
dodgeman52
i took my pan off without lifting the motor up. i would change the oil pump and screen and see if that fixes ur problem first before u do anything else
Old Aug 4, 2010 | 08:09 PM
Kurylo's Avatar
Kurylo
sounds like a lifter, but the oil pressure drop might be associated with cam bearings, crank bearings, and oil pump.
Old Aug 9, 2010 | 09:03 AM
79jon's Avatar
79jon
Ok.. so this weekend I dove off into the oil pan. I bought a new Melling Standard pump and Melling screen. When I pulled the pan, I was expecting sludge everywhere, but the screen and pan were surprisingly spotless. hmm There were a few specs of stuff here and there but nothing blocking the screen from what I could tell. So I replaced the pump and screen and cleaned the pan spotless and put it all back in. After filling it up with oil I took it for a drive for about 10-15 min. Before when you would drive it for about 10 min or so the oil pressure gauge would drop to zero at a stop light or idle then go back up when you give it gas. I noticed the gauge never dropping or anything. I then drove it another 45 miles of highway and stop and go and the gauge never dropped. So im thinking it fixed the gauge problem however i could still hear that tapping i described earlier. Ok.. now here is the weird thing.. After test driving it around with no problems with the gauge dropping at idle.. i was driving it around yesterday.. (Sunday) and about 30 min into the drive i pull up to a light and the gauge dropped again. UGH!!!!! and now every time I sit at idle it drops. The motor sounds fine and the RPM's stay the same. Can someone tell me what the problem is now? Sending unit? PCV?
Old Aug 9, 2010 | 10:29 AM
Pick up a cheap mechanical gauge. I got one from Advance for under 20 bucks. Put that in place of the electronic sending unit (yeah, I know, do you have your arm with it's third elbow handy?) and place the gauge somewhere you can see it. (doesn't have to be permanently mounted.....) Go for a drive. See what the Oil pressure is REALLY doing. If it does NOT exhibit the same behavior, replace the sending unit. If it DOES..... well, start saving your pennies for a rebuild.
Old Aug 10, 2010 | 04:26 PM
79jon's Avatar
79jon
This weekend Im going to put a mechanical gauge on it to see what its doing. In the meantime, i have a question about the PCV.. When I first bought it, I bought the typical tuneup stuff.. Oil, plugs, and PCV. I'm wondering if that new PCV is causing some of this? Allowing the oil to get in the intake possibly? I did notice that this new PCV makes a gawd awful sound like a severe buzzing and its physically vibrating. Is that normal? Im just wondering if that new PCV is causing some of the problems maybe. Bad thing is I think i threw away the factory one, so I guess I need to run to the dealership to get one. The one I got was at O'Rielly's. Also the PCV has oil on the end of it when you take it out. Im wondering if thats getting sucked into the intake.
