camper trailer
Old Aug 2, 2010 | 10:20 AM
yellowbeast's Avatar
yellowbeast
Default camper trailer
i have a 99 dodge ram 1500 sport 4x4 with 5.2l engine and looking at buying a 26 ft camper trailer that way roughly 5000lbs it has one of the weight distrobution hitches on it i was wondering if it would be ok to pull with my ram thanks for your answers
Old Aug 2, 2010 | 10:23 AM
BigRedRam95's Avatar
BigRedRam95
should be out rams are rated to pull like 7000Lb+
Old Aug 2, 2010 | 05:13 PM
SnowFox's Avatar
SnowFox
got a 28-30 ft 5th wheel that weighs about 6,500-7,000 pounds and it pulls it pretty good
but the truck is a 99 1500 with the 5.9 and custom made helper springs that he got at spring service in johnson city
Old Aug 2, 2010 | 10:09 PM
dhvaughan's Avatar
dhvaughan
stock dodge transmissions are not known for reliability. if yours has never been rebuilt, the odds are pretty high that it won't stand the strain.
things you must do are - put in a big transmission cooler. tow with OD off. change fluid and filter regularly. keep your tires small to keep your gear ratio lower. consider regearing even lower to 4.10 or 4.56
things you should do if you need a rebuild - rebuild with heavy duty towing parts including torque converter. rebuild with all the tricks to improve lube and cooling.
Old Aug 2, 2010 | 11:19 PM
FarmBoy428's Avatar
FarmBoy428
Your 5.2L should have no problem towing a 5k LBS trailer. But i do have the 5.9L Mag, it really shouldnt make a dif. Our 5.2L and 5.9L Mags were built solid with a lot of torque.
Old Aug 3, 2010 | 01:32 AM
CappinHoff's Avatar
CappinHoff
It's not the engine that is the issue, it's the tranny. Depending on how often you pull that trailer a tranny cooler would be ideal.
Old Aug 3, 2010 | 01:39 AM
EvIl KrAkEn's Avatar
EvIl KrAkEn
5000lb with a 5.2 shouldnt be a problem we got a 8500 lb with my 5.9 and barley squatted, just make sure od is off and dont go too fast
Old Aug 3, 2010 | 04:08 AM
ColoradoRamLover's Avatar
ColoradoRamLover
personally Id go out and buy a new truck. Even a 2nd gen cummins or 3rd gen hemi. It might be better a better way to go. Itll save the hassle of having to upgrade all that and have the headache of spending 2 grand on a rebuilt tranny...
I dont know, thats what my dad did. We bought a 26-28ft trailer and got a new truck that could pull it with out having to worry.
Old Aug 3, 2010 | 02:00 PM
yellowbeast
My transmission was rebuilt shortly before I bought it and unfortunately being a full time student I can't afford a new truck but I will drive carefully and with the od off
Old Aug 3, 2010 | 03:36 PM
ColoradoRamLover
I definitely know how that feels! not much to nada dinero lol
