Help!! Overheating problem
Old Aug 3, 2010 | 06:21 PM
SplatSTi's Avatar
SplatSTi
Unhappy Help!! Overheating problem
OK so I changed the thermostat and I thought it was fine, took it for a run, over heated. The only time the temp came down was when I hit to to 5000rpm. I was like ugg! I barely made it home.
I let it cool down and took the thermostat out and of course, stripped the thread, so I drilled and tapped with helicoil. Put the housing back on with no thermostat and started her up.
I flushed the engine out with water, I havent put any engine flush in yet, I was going to do that but I wanted to make sure it wasnt mechanical before I wasted my time. Theres no point if its not circulating.
I left the cap off so I could see if the water was circulating..... and..... its not. Went back in the back and the temp is above 220F I gun the engine and it immediately drops the temp for a min then start heading to the hot zone again.
Do I have a bad water pump?
Do I have something blocked somewhere?
/fustrated!!
Old Aug 3, 2010 | 06:27 PM
CPTAFW163's Avatar
CPTAFW163
The impeller in the water pump could be messed up. I would say to try some radiator flush, but if it is not flowing...there will be no flushing.
Or you could have a rat stuck in your hose.
Replace the water pump, and send some radiator flush through there. Napa brand radiator flush and descaler worked great for me. I have a 180* stat and it does not get over 180* here min arkansas with 110* weather. I did a 60/40 water/antifreeze mix though. I will havem to change that to 50/50 for the winter though, but that is fun maintenance. Especially when you bought more antifreeze than you needed the first time :P
Old Aug 3, 2010 | 06:37 PM
SplatSTi's Avatar
SplatSTi
Ugg! OK. Time to get a water pump.
The Magnum engine uses a reverse water pump correct?
OK Autozone has them for $45 including the gasket.
Edit:
OK Picked up the pump and some tool to get the fan off lol.
Old Aug 3, 2010 | 11:23 PM
Darrell67's Avatar
Darrell67
The small hose for the bypass is a pain to remove, even with the bracket for the alternator and the a/c out of the way. (Just did my water pump last week.) Only other advice I can offer is don't misplace that little o-ring that comes with the pump. I wasted a good 20 minutes looking for it.
Have fun. Your truck's looking good.
Old Aug 10, 2010 | 11:23 AM
SplatSTi's Avatar
SplatSTi
OK, water pump has been replaced, wasnt too bad at all.
The test run
Old Aug 10, 2010 | 12:08 PM
CPTAFW163's Avatar
CPTAFW163
congrats. THat impeller has seen better days!!!
Old Aug 10, 2010 | 06:10 PM
loneriderty's Avatar
loneriderty
mine has a thermostat that with it hit over 250 it reduces the power or shut the truck off and won't start till it cools to keep fromblowing a head gasket in florida summers i run 90/10 90 antifreeze and 10 water helps
Old Aug 10, 2010 | 07:59 PM
CPTAFW163's Avatar
CPTAFW163
Ok, someone has fed you a load of BS. Let me explain:
1. There is no thermostat that turns your truck off when it goes over 250. All a thermostat does is open and close and allow water to exit the engine and go into the radiator. There is no electrical connection on a thermostat.
2. 90% antifreeze and 10% water will make you overheat. Water dissapates heat better than antifreeze. I run 60% water and 40% antifreeze in Arkansas. It was 110 here a few days ago. My truck stays at 180 with the AC on.
So, if I were you, I would change your coolant out and add more water.
Old Aug 10, 2010 | 08:00 PM
JRob238's Avatar
JRob238
wish mine had only been a water pump! Getting freeze plugs changed as we speak
