hi flow cats ???
Old Aug 4, 2010 | 11:50 AM
mikentiff's Avatar
mikentiff
Default hi flow cats ???
I have a 6 ram 5.2. Who makes a good cheap hi flow cat ? How much will it change my power/mpg ?
Old Aug 4, 2010 | 12:00 PM
Salex007's Avatar
Salex007
So im assuming you have a 96 ram, get a magnaflow off of summit for like 80 bucks, nice increase in sound along with power and a little better passing power, what are your exhaust plans?
Old Aug 4, 2010 | 12:10 PM
mikentiff's Avatar
mikentiff
flowmaster duals
Old Aug 4, 2010 | 12:13 PM
mikentiff's Avatar
mikentiff
I looked on summit and didn't see one that cheap. Also will it make my CEL come on ?
Old Aug 4, 2010 | 12:30 PM
RM_Indy's Avatar
RM_Indy
Will not cause a CEL, use them on my 96 as well.
Direct fit is 207 & includes a better ypipe setup that replaces the very restrictive stock ypipe arrangement
http://www.summitracing.com/parts/MPE-23285/
Old Aug 4, 2010 | 12:32 PM
mikentiff's Avatar
mikentiff
So how will it effect my mpg ?
Old Aug 4, 2010 | 12:33 PM
mikentiff's Avatar
mikentiff
Is that if your running true duals I don't have that ?
Old Aug 4, 2010 | 12:36 PM
Salex007's Avatar
Salex007
you can buy just the cat for like 80 bucks is what i meant, but the link rm_indy provided is much better because it comes with new pipes and not a restrictive y-pipe, that link is for not true duals cat, expect a gain of mpg if you can keep your foot of it
Old Aug 4, 2010 | 01:04 PM
UnregisteredUser's Avatar
UnregisteredUser
It's a single-out arrangement. I've got one in a box now just waiting to be installed. It even comes with a blocking bolt if you should want to ditch the post-cat oxygen sensor for some silly reason.
Old Aug 4, 2010 | 03:14 PM
RM_Indy's Avatar
RM_Indy
As mentioned thats for a single exhaust.
When I added the first h/f had Eddy hdrs, ypipe & a catback as well as K&N 14" & 3pc u/d pulleys with stock 5.9.
Saw .32 off my avg ets from just the cat (dual in/single 3" out).
When the oem cat started to plug the truck slowed, before/after difference was over .4 sec.
One of the largest gains I got from track testing individual bolt ons while retaining a bone stock 5.9.
