rusty frame
Old Aug 4, 2010 | 04:01 PM
The beast is reborn's Avatar
The beast is reborn
Default rusty frame
Good day everyone, just started getting my 95 ram back on the road after sitting for 7 years. I'm going to try and clean the frame up alittle. I have two ways ahead.
1- use a wire wheel and take off as much rust as possible and then treat
or 2- use a wire brush get the biggest off and then treat
Treating- rust converter, rust paint then a undercoating.
Any thoughts on this issue would be greatly appreciated
Old Aug 4, 2010 | 04:07 PM
lane's Avatar
lane
i would like to know what you guys think also!
Old Aug 4, 2010 | 08:02 PM
Kurylo's Avatar
Kurylo
Clean the frame the best you can the paint it with POR415. This stuff is great. A friend did it to his snow plow and his 72 Chevelle frame, this stuff is indestructable.
Old Aug 4, 2010 | 08:37 PM
RM_Indy's Avatar
RM_Indy
Its called POR15
Painted my Indy frame with it.
Another choice is Eastwoods Rust Encapsulator.
Old Aug 4, 2010 | 08:39 PM
lane's Avatar
lane
so would i need to grind the frame down to bare metal?
Old Aug 5, 2010 | 12:58 AM
03neonSE's Avatar
03neonSE
Rustoleum has been working well for me. I knock off all the loose stuff, clean the area with Permatex Degreaser and paint once its dried. It's been holding up well.
Old Aug 5, 2010 | 01:08 AM
SplatSTi's Avatar
SplatSTi
I say you bead blast the frame and then paint it, at least thats what I am going to do with mine.
I bought a little blaster for harbor freight for like $30 and it uses 50 psi which my little air compressor can handle and just got some clean sand to blast it with. If you like, I will take some pictures this weekend and post. Im doing the drivers side upper A Arm.
Old Aug 5, 2010 | 05:57 AM
Trouble is, there are things on the frame that won't particularly care for being media blasted. Wiring harness, brake lines........
Old Aug 5, 2010 | 11:44 AM
RM_Indy's Avatar
RM_Indy
Splat, Im no expert but I have been doing media blasting at home for a few years now.
Ive tried all the cheapo setups & they DO NOT WORK.
I strongly suggest you return the blaster to HF, its pretty well completely useless I found.
To keep media flowing had to hold the strap in one hand & lift & drop it constantly or it wouldnt flow longer than about 5-10seconds.
Fine sand dust particals are extremely dangerous to your health.
NEVER USE SAND!! It will cause silicosis.
Soda, glass bead, aluminum oxide & walnut shells about the only media you should use.
Its available in various grits.
Without a way of recovering the media you would go through literally a few hundred lbs of medai
Blasting you want about 80-90psi at the gun tip.
Ideally compressor with 80-120gal tank, 175psi, 20cfm or more needed (12cfm about min)
175psi means you have about 40% more air volume inside the same sized tank as one with 120psi
Couple years I used a cheapo 120v/20gal/120psi/5.5cfm compressor.
I killed it from blasting. Way beyond its ability & duty cycle, constantly running.
Currently have 80gal/150psi/14cfm. Was all I could afford or have space for.
Truck frame needs to be completely bare of all parts including the body/cab/bed/suspension/fuel/brake & electrical systems if you want to blast it.
Whatever you leave attached will also get blasted.(media bounces)
In a dry environment you have about 5hrs max after getting to bare metal before surface rust starts.
In a humid environment you have even less time.
Must coat the exposed surface in that time or you have wasted your time.
Old Aug 5, 2010 | 12:21 PM
RM_Indy's Avatar
RM_Indy
Forgot to mention
Blasting outside you want to get a pressurized bottle type.
Most hold about 100lbs of media
http://www.harborfreight.com/110-lb-...ter-95014.html
