Tranny problems
Old Aug 4, 2010 | 08:17 PM
DieselPowerRam's Avatar
DieselPowerRam
Default Tranny problems
Ive got a 95 Ram 1500. Its got the 46re tranny in it and its messed...i have a friend willing to give me his old truck with a 46re in it...but its a 99...if this dosent work i will have to shell out 2000 dollars for a rebuild
THANKS
Old Aug 6, 2010 | 12:29 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
If its the original transmission, your 1995 has a 46RH, not a RE. They went to the RE transmissions in the 1996 model year.
The 1999 transmission will have some wiring differences (the wiring harness will not be the same), so you'll have to do a custom wiring job somehow from one harness to another (if its even possible).
Let me move this over to 2nd gen to try and get you some additional help.
Old Aug 6, 2010 | 11:25 AM
Aubrey's Avatar
Aubrey
I don't know for sure but, I'm going to guess it is not going to work all that well. The 46re is going to need additional signals from the computer to control it. Your OBDI isn't gonna be able to do that.
Old Aug 6, 2010 | 12:31 PM
J415's Avatar
J415
It won't work. the over drive unit on the RE's is electronically controlled and the RH is hydraulically controlled.
Old Aug 6, 2010 | 12:35 PM
J McWillis's Avatar
J McWillis
It'll work.. if you switch the entire truck over to OBDII.. no small task.
Old Aug 6, 2010 | 03:26 PM
J415's Avatar
J415
Very true...I'm always the pessimist!!!
Old Aug 6, 2010 | 06:50 PM
DieselPowerRam
Thanks very much...i had assumed i had the 46re because of the same generations on both trucks...but i guess not haha...well time to start a rebuild?
Old Aug 6, 2010 | 09:39 PM
There is a REALLY good article for it in the FAQ section by j415.
