Broke the spider gears, what are my options?
Old Aug 9, 2010 | 02:20 PM
Sheriff420's Avatar
Sheriff420
Automatic lockers will make your rear tires wear out faster, keep that in mind before you get one.
Also, the one you found is for a Dana 44, not the Chrysler 9.25.
Old Aug 9, 2010 | 05:53 PM
Relex's Avatar
Relex
Got the spiders out.
IMG_20100809_144529.jpg?t=1281390674
What am I missing for getting the carrier out? Pulled the axles shafts got out the to brackets holding it in. The carrier moves about half an inch and stops. Tried taking pry bars to it like how I got the front end out and this doesn't seem to want to come out.
Is there something I'm missing?
Old Aug 9, 2010 | 06:52 PM
aim4squirrels's Avatar
aim4squirrels
I may be wrong, but I think the carrier has to go up and out. I think there is a lip there that it sits in.
Old Aug 9, 2010 | 06:56 PM
aim4squirrels
Originally Posted by Sheriff420
Too bad I haven't installed my new gears yet, I'd send you my spider gears.
Sheriff, are you putting in a locker? You'll need the spiders if it's just a gear swap.
Old Aug 9, 2010 | 07:11 PM
Relex's Avatar
Relex
Was calling around and found a place near by that sells stuff by how much it is worth in scrap and I can find an axle the whole thing will be $100.
Can't really beat that deal.
Old Aug 9, 2010 | 08:22 PM
kissmymagnum's Avatar
kissmymagnum
There are two slack adjusters (also known as bearing preloaders) that you have to back off, one on each side... The tool that I have seen goes into the axle tube all the way up to the carrier bearings like a type of driver
http://www.sjdiscounttools.com/otc6602.html
Follow the link to see what I am referring to if you have never heard of it before. I first saw this type of tool used on an older GM but I know that is what is holding you from getting yours apart as I had the same thing in my '99
Old Aug 10, 2010 | 09:23 AM
Sheriff420's Avatar
Sheriff420
Dual truetracs.
Old Aug 10, 2010 | 03:56 PM
Relex's Avatar
Relex
Ended up going to a near by junk yard and got spiders for $25. It was 25 for the whole diff but since I never got mine out and it was hot so I just got the spider. I was going to get a hitch for $20 but I didn't have the right size deep wall socket.
Old Aug 10, 2010 | 05:06 PM
Hahns5.2's Avatar
Hahns5.2
Not really, the extra tire wear is negligible in my experiance.
Too late now but my vote would be to throw a Lock-Right or No-Slip in there.
Old Aug 10, 2010 | 06:43 PM
Sheriff420's Avatar
Sheriff420
I was thinking of a Detroit automatic locker, assuming a Lock-Right would lock up as often as the Detroit. The guy at Randy's ring and pinion, and two guys on here all told me that they get increased tire wear with a Detroit.
A No-Slip is a different story though, I haven't heard anything bad about those.
